okay, this is the story. I'm tryin to make a vcd with Nero, so I chose VCD NEW, than dragged and dropped my video files over to the other window on the left, so after i did that, I clicked on Write CD, than on Write. After that, another screen popped up and it says at the top "DONE"under that, "Compilation" than a white screen under that says ? 6:20:01pm encoder
6:20:04pm c\program files\etc.....
than at the very bottom of the screen it asks me if i want to save it, print it or discard it. So I printed it, than nothing. It didn't do anything, so does anyone out there know what the hell went wrong, and what is that screen that pops up and why the hell it won't download. Please help me. I'm a beginner in all of this, so I don't know all the harsh computer talk. Also, the files that I wanted to burn were mpeg and avi which i hear is possible with Nero. I thank you all so much in advance if you can help me out.
Results 1 to 10 of 10
The screen you ar looking at is the message log. If you try to save, it you will notice it has a default name of "log". The line items are merely what was going on during the burn process. Did it burn?
I'm afraid you have the program on Vitural Drive... How long did it burn?
Hi there, thanks so much for anwering, okay well it didn't burn at all. it did nothing after that pop up screen. How do i burn after that. I don't have a clue, i'm a beginner. Thanks so much
Hey i had the same problem, well im having the same problem. i get a message coming up that says not enough memory and then even when i got it to work before it said it wasnt in the right format. well it was in mpg format which i believe is needed for VCD but i still cant get it to work. good luck, ill be looking over posts.
If it didn't burn the disc then the program may be on "IMAGE RECORDER". To check this and to change it, click on the recorder menu and select "Choose Recorder", if it is on Image Recorder, then that is the problem. Just select the CR-RW drive below it and it will also tell you what the drives specialties are also!
Hi there, yeah I checked that already and it's not that, it has always been cdrw. i am so lost, does anybody know a better vcd burning program that is relativly cheap or better yet free (something I can download), OTHER than NTCDmaker, that program sucks, it kept on crashing my computer. Please all, i need help.
I'm having the same problem overhere. After start burning Nero says its ready. The log screen only shows the two lines with no further info.
i had the same problem with nero after downloading the 5.5 upgrade.
there is an extra file you can download to resolve the problem.
ftp://ftp5.nero.com/NeroVCD.zip
if the above link doesn't work the site address is:
http://www.ahead.de/en/download.htm -
I think on Nero 5.5 you have to enable "test all speeds" or so, I'm not sure.
Instead try using Nero 5.0, I found it better.....
<font size=-1>[ This Message was edited by: Max7 on 2001-11-04 09:18:48 ]</font>
nero burning failed
By KristijanR in forum Newbie / General discussionsReplies: 1Last Post: 6th Jul 2009, 01:10 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Nero only burning at 1x...?
By VEBouto in forum Newbie / General discussionsReplies: 2Last Post: 20th Jun 2008, 22:04 -
NERO burning help
By efiste2 in forum Authoring (DVD)Replies: 6Last Post: 11th Jan 2008, 08:35 -
burning problems with nero 6
By jjob222 in forum Newbie / General discussionsReplies: 6Last Post: 16th Jun 2007, 15:36
