Hi!
I have just started burning DVDs after buying a new DVD burner. Previously I would use VideoCDs. The software I use is TMPGEnc, but I have encountered a problem.
Some of my AVI files that I wish to re-encode are NTSCFilm format, and TMPGEnc had settings you could load for those files for VCDs. However, there are no settings in TMPGEnc for NTSCFilm DVDs. This is frustrating, because if I choose PAL format or NTSC format there are jerky moments in the playback of the film due to the poor sync.
Does anyone know of a way to get DVDs to encode in the NTSCfilm format on TMPGEnc?
Thanks for your help,
Dan
bugster posted 2003 Oct 13 10:32
23.97fps is not valid for DVD as such
You can encode at 23.97fps with 3:2 pulldown. This adds flags to the mpeg stream that allow it to be played back at 29.97fps. Without these flags 23.97fps is invalid for DVD.
Mpeg-1 on dvd must be 29.97fps as mpeg-1 does not support pulldown.
This is all for NTSC of course.
Authoring MP3 DVDs with Loop Playback option
By flower07 in forum Authoring (DVD)Replies: 4Last Post: 1st Sep 2011, 15:46 -
Best option to back up dvds to ISO? Free or pay
By AndyD in forum DVD RippingReplies: 10Last Post: 1st Mar 2010, 11:29 -
help burning dvds
By bunty90 in forum Authoring (DVD)Replies: 2Last Post: 3rd Aug 2008, 13:53 -
burning dvds
By terrie29 in forum Newbie / General discussionsReplies: 7Last Post: 7th Oct 2007, 19:08 -
Burning HD DVDs...Help!
By Anonymous55 in forum Authoring (DVD)Replies: 6Last Post: 14th Jun 2007, 21:37
