Hello
I am trying to backup some of my DVDs using a mixture of ANYDVD and CLONE DVD 2.
Most of the ones I have done so fat have worked, my question is about he couple that don't seem to want to work.
The reading process on Clone DVD usually gets to a certain percentage then hits a VOB which it can't read. I have tried cleaning the DVD but I really don't think that is the problem.
I think for some reason or another the VOB is not accessable.
Anybody encountered this problem before or even have a solution to it?
Many thanks.
Unfortunaetly not all drives, and media (blank and pre-recorded) are created equal, and glitches like this can occur.Originally Posted by Bigmonty
Although i dont use the same software as you (i use DVD Shrink, Nero and DVD Decrypter) i have had similar problems.
I got round it by using my other DVD drive to read the disc initially, and this worked first time without any problems.
Zworg2
Question about audio when ripping DVD to AVI file
By joylamyy in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2011, 15:56 -
Question about extra (mystery) chains when ripping DVD with FairUseWizard
By jimdagys in forum DVD RippingReplies: 6Last Post: 28th Dec 2010, 18:26 -
DVD Ripping and conveting to AVI question
By undyingforce in forum DVD RippingReplies: 4Last Post: 24th Apr 2010, 13:05 -
ripping a dvd to mkv h264 filesize question
By stackner in forum DVD RippingReplies: 5Last Post: 16th Jan 2009, 18:13 -
DVD Ripping then Convert Question
By frodamob in forum DVD RippingReplies: 4Last Post: 23rd Dec 2008, 23:09
