  1. Lover of all things retro
    Arizona
    I was sick of burning at a whopping 4x speed on overpriced CDRWs...did a little searching of compatible CDRs since Sony DVD players don't like CDR and bought the recommended Prime Peripherals CDRs...work like a charm and burning at 12x on my Plextor. 50 Pack spindle for $14.00. Cheap.
  2. where did u buy them i would like to try them on my sony dvd/vcd/cd player to see if they work ..thanks
    Jan 2001
    Vancouver/Portland
    Does your Prime Peripherals have "PRINCO" inscribed in the center ring? Or... did you run CDRIdentifer and it displayed that it was made by Princo?
    *Some* not all Prime Peripherals CDRs are made by Princo. The ones I currently possess aren't. =|
    Princo CDRs are known to be compatible on most DVD Players.
  4. Lover of all things retro
    Arizona
    Jeomite: Guess I'm lucky then cuz mine say Princo on the inner ring. I'm gonna go pick up the 2 packs they have left. Can't beat 14.00 for a 50 Pack of Sony compatible CDR.
    Pinoy2201: I bought them at Office Max.
  5. thanx vice86 im going to buy sum this saturday thanx for the help
  6. i bought some Prime Peripherals awhile back cause i heard the same thing. there great for video media, since i only have apexs in my house i couldn't test them on sony.
    "A good song should make you wanna tap your foot and get with your girl. A great song should destroy cops and set fire to the suburbs. I'm only interested in writing great songs." Tom Morello in Alternative Press
