Ok this thing costs arm and a leg but DeAmmN the PAL framerate looks very good.
I just thought that this may look interesting to some ppl.
The video I tested got some blurring in there but I think that would be acceptable at least for me. Note: the video I tested is actually captured at 352x240.
Probably if I were to do something larger than this resolution I'd get better results.
http://www.focusinfo.com/products/firestore/DVConversionSuite/dvcsuite.html
Application is so easy to use. So far I only were using uncompressed avi. (this is some dv application for cameras I think and it has some dsvd codec or something. I'd rather stick to uncompressed avi (look up the box that says Microsoft DV and change it to uncompressed avi)..
I think that's it. The rest is easy.
B.T.W even though it is exe file, it looks like it was made in some non-windows environment (application resembles linux look). Well whatever.
Dink
Results 1 to 1 of 1
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
Convert PAL to NTSC?
By killerteengohan in forum Video ConversionReplies: 32Last Post: 7th Feb 2012, 12:33 -
By rock.freak667 in forum DVD RippingReplies: 8Last Post: 21st Jul 2009, 09:16 -
How to convert NTSC to PAL?
By jebinio in forum Video ConversionReplies: 15Last Post: 8th May 2009, 20:03 -
How to convert PAL DV to NTSC (I ONLY have NTSC DV camcorder to play with)
By inspiron2 in forum Video ConversionReplies: 4Last Post: 7th Jul 2008, 22:45
