Results 1 to 11 of 11
    Feb 2004
    Shire - middelearth
    H E L P
    I have this ripped DVD on my HD, the .vob files goes from _01_1.vob to vts_01_32.vob...
    But nero won't take vts_01_10.vob and up .........
    What am I to do ????? , any other good burning program, rename ? ?? ???
    g_i_l_s_t_e_r
    Just the product of a society that's lost it's good manneres
  2. do all the vob files fit onto one dvd-r?
    Feb 2004
    Shire - middelearth
    it's around 4.3 GB, so it's should be able to fit one DVD+R,
    When I ripped long ago, I ripped so 1 (vob) = 1 (chapter), the plan was to convert it to SVCD, but now I got a DVD-burner....
    g_i_l_s_t_e_r
  4. i would do what mat suggested.
    create an iso and burn using dvddecrypter.
    Feb 2004
    Shire - middelearth
    how do I make an ISO, ???? is it here the " Imgtools Classic " come in..........................................
    g_i_l_s_t_e_r
  6. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Yes, exactly! It makes (as far as I've experienced) the most DVD player compatible file system possible. A real no-brainer too - no settings to tinker with - just select where your AUDIO_TS and VIDEO_TS folders are located, select where you want the ISO, and off it goes.
    /Mats
    Feb 2004
    Shire - middelearth
    cheers
    thx alot,; mats and freak
    g_i_l_s_t_e_r
  8. HHmm..
    I wonder why Nero doesnt like them.
    Actaully it doesnt make sense because normally vob files would be 1 gig each.
    it would be something like
    vts_01 1gb
    vts_02 1gb
    vts_03 1gb
    vts_04 500 mb
    So if you had 32 continous vob files it would be 32 gb big.
    I know you sometimes see DVDs that dont follow this procedure but its hard to understand how they were built like that.
  9. Hi,
    if you ripped each chapter as a single vob, then you have to reauthor your dvd first. Because any vob should be 1GB (ecept the last one[could be shorter] depending on the movie). First use VobEdit (see Guides) and join your vob's together, then Author your new Dvd with IfoEdit (see Guides again). If you don't do it in this way (or similar) you will have a non standart Dvd.
    P.s. Be Patient with my English
    Feb 2004
    Shire - middelearth
    thx again.....!
    Like FIW said, I did rip them as each chapter as a single vob (pretty stupid I know that now), but gonna look into the reauthoring - stuff and try burn it this weekend , will post an update on how it went, hopefully succesfull......
    g_i_l_s_t_e_r
