First I need to apologize for asking the question again.
I know this might have been answered many time. I spent about 3 hr now searching the forums and give up.
I bought CANOPUS ADVC-1394 card and captured using the provided Stripped off Vegas 3.0 LE software. It captured will with out any problems. (no audio or frame dropping issues).
Using the provided WinProducer 3 I created DVD on CD (ie Mini DVD), VCD (mpeg1) in both instances, the quality turned out to be quite bad. (Both on TV & PC). Audio was distorted. Video was pixel’ed/blocked on the TV screen.
Then tried to use TMPGEnc to generate MPEG1/MPEG2 files. The files were of a much lower quality then the WinProducer.
Then installed Roxio Video Wave movie Creator. Created a Mini DVD (DVD on CD). The over all quality was better then the above 2 instances, but still far inferior to the actual capture file (Uncompressed DV- AVI).
Now I need suggestions are to what software is preferable in this case to convert these huge AVI’s to a more “storable” format?
Any suggestions are greatly appreciated.
Thanks….
Hi nufdude,
This thread:
https://www.videohelp.com/forum/viewtopic.php?t=208085&highlight=
...might be of interest. My reply to the post details high-level info that might be of use.
Although you're capturing a different way, you still have AVI's that will then follow the same process and steps, as described.
Post back with anything you're stuck on...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
How to convert RM/RMVB to AVI or MPEG1/2
By kschang in forum User guidesReplies: 112Last Post: 11th Feb 2012, 19:56 -
Capture...convert...confused!!!
By cyber-junkie in forum Newbie / General discussionsReplies: 10Last Post: 15th Jan 2010, 13:11 -
HD Capture - Any way to convert from 1080p60 to 1080p24?
By Corvius in forum Capturing and VCRReplies: 4Last Post: 8th Nov 2008, 06:16 -
TV Capture/Convert lost my color?
By WDude in forum Capturing and VCRReplies: 4Last Post: 11th Jan 2008, 16:20 -
Trying to convert WMV to MPEG1 on a slow processor
By Gooey in forum Video ConversionReplies: 2Last Post: 21st May 2007, 03:59
