Do I have to install a new codec? When I import an Mpeg2 video into Premier I don't see the image, only the sound.
premiere doesn't really edit mpeg2 . though there is plugins to do so ...
even then - premiere 6 is not a mpeg2 editor and shouldn't be used for it .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Is it possible to frameserve the mpeg to Premiere? I tried to but Adobe kept saying it was corrupt or an unsupported type. I read almost all of the guides, but could not get it to work. Most of the guides focus on frameserving from Premiere or to TMPGEnc, could the same be applied to Premiere. I found one that was specify designed to frameserve to Premiere, but it involved using project files and VOBs.
Edit/cut MPEG2 TS
By jon222 in forum Newbie / General discussionsReplies: 10Last Post: 11th May 2014, 15:30 -
How to import MPEG2-TS to Adobe Premier? How to convert MPEG2-TS to MKV? :)
By farzad in forum EditingReplies: 19Last Post: 29th Feb 2012, 16:25 -
Can't edit video file converted from DVD to AVI in Adobe Premier
By GalMed in forum EditingReplies: 12Last Post: 24th Feb 2012, 13:53 -
How to edit video in Pro Res over Windows using Premier Pro2?
By Cyclope in forum Newbie / General discussionsReplies: 4Last Post: 8th Oct 2010, 18:09 -
MPEG2 file plays in windows media player but not properly in premier cs3
By ibanezfreak in forum EditingReplies: 1Last Post: 20th Oct 2008, 03:42
