I was just trying to burn my first dvd but having problems. I captured, edited and authored my project using WinDVD creator, selected to burn on CD with no problem. When I tried the same and then burn to DVD, the program rendered it into movie format ok, but when it was in the process of formatting the DVD it stalls. I tried using both a -R and a +R but get the same results. Basicly the progress line shows it's completed but don't go to the burn level. I let it go overnight just to be sure but still nothing.
Does this make sense to anyone here?
btw, after a few tries of this I did get an error once that only said "there was some error" that was it.
Thanks for any support on this
Rob
I got the same error when I tried to burn a dvd. Did you ever find a solution to this error? Intervideo's website and support are useless.
Same here...Thought upgrading to Platimum version would cure that...no help. Platinum version crashed big time on my XP machine 3.0/1gig.
Started to make movie, about 1 minute in, crash. Called tech support and they had no idea. Offered to refund my money...took the offer.
Other than that...This is the best Capture/edit/author/burn package I've seen. Hope they fix the problem. I would definately buy it then.
Re: getting interactive chapter marks windvd creator 2
By tomcat862 in forum Newbie / General discussionsReplies: 1Last Post: 28th Feb 2008, 14:38 -
WinDVD creator 2 won't allow dvd
By CullenJ in forum Authoring (DVD)Replies: 3Last Post: 20th Jan 2008, 20:57 -
WinDVD Creator 2 - Subtitles Disappear
By scooter1203 in forum SubtitleReplies: 2Last Post: 11th Oct 2007, 07:39 -
Cannot get audio in Windvd creator 3 under windows vista.
By syllinx in forum Capturing and VCRReplies: 0Last Post: 13th Jul 2007, 23:43 -
WinDVD Creator 3 not recognizing .AVI
By wmrjw in forum Authoring (DVD)Replies: 4Last Post: 28th Jun 2007, 18:15
