Is there a way to burn avi. on a dvd to play on a Lite-on 2002. Here is what I tried. Burned Xvid and Divx 4 or better files on a dvd +r (Memorex) disc. I use nero 6.0 and burned them as iso. files using a lite-on 811. A few played but froze part-way into the movie. The rest didn't load. I then tried burning them as a DVD-video file. When I tested it using a Imation DVD +RW all movie played without problem. Not so when burned with a DVD+r (Memorex). No movies played and none loaded. All firm ware has been upgraded. Thanks for any help.
did you try a dvd-r disc.
it seems the only media so far you have tried is +,except the dvd-rw,and that worked,more than likely as your player will accept - media. -
I am not surprised, Liteon has a lot of glitches, specifically if you want to burn a bunch of avi movies on one DVD+, it freezes quite often. It is the player not the disk
AVI on CDRW stops playing in DVD player?
By leonk in forum Newbie / General discussionsReplies: 10Last Post: 19th May 2012, 22:53 -
avi not playing full length on DVD player
By David Banner in forum Newbie / General discussionsReplies: 9Last Post: 23rd Nov 2011, 16:21 -
DVD Player problem playing .avi
By dexter30 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 17th Sep 2009, 01:18 -
Avi subtitle not tally while playing in DVD player
By jackwolf in forum DVD & Blu-ray PlayersReplies: 1Last Post: 25th Aug 2009, 06:43 -
AVI to DVD playing on PS3
By silv in forum ffmpegX general discussionReplies: 2Last Post: 11th Oct 2008, 15:06
