Okay, I've been to several forums and help sites and am still not able to obtain a solution to the following:
All my research indicates that my subject DVD player can play both DVD+R and DVD-R disks. The machine has no problem with the first format but does not play the latter. I get play the title page of a movie but then the player freezes and eventually I get a "Disk Error" message.
The disk, by the way, plays well on my computer using both Power DVD and Win DVD.
If the XMS 750 is supposedly compatible with both disk formats why am I having difficulties?
Has anyone else encountered similar problems?
All comments/advise is appreciated.
Regards,
Rick
RICK
Hello Magwa,
So far have tried 3 different brands and none have worked. Do not want to spend on any more until I find out for sure if my player can, or can not, play DVD-R disks.
Magwa? You liked Last of the Mohicans too?
Cheers,RICK -
I also found the XMS-750 was a bit flakey with DVD-Rs. It does not indicate that it supports DVD-Rs either on the box or in the manual. So I took it back and swapped it for an XMS-888. Bingo
DVD shows me 750 gigs????
By lj5 in forum DVD RippingReplies: 10Last Post: 5th Feb 2010, 04:02 -
Backing up to Hard Disks-Not using Disks any longer.
By cal_tony in forum DVD RippingReplies: 5Last Post: 31st Dec 2009, 13:40 -
Hack for LG LD 750???
By sunnjack in forum Newbie / General discussionsReplies: 1Last Post: 14th Jan 2009, 14:51 -
XMS-100PD Slim Line DVD Player (region free hack inside)
By iceman654 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 6th Mar 2008, 08:55 -
Cost of disks, blue ray or HD DVD, for data storage? Any good disks?
By overloaded_ide in forum MediaReplies: 16Last Post: 9th Nov 2007, 11:24
