I have been using TMPGEnc to encode AVI files into DVD comliant elementary audio and video streams.
This normally takes around 6- 8 hours
This i can live with, leave it running overnight.
However the most recent file i have TMPGEnc says that it is going to take over 14 hors !!! to encode.
Does this sound normal??? The file isnt any bigger than normal, and the quality is much the same!!
Is there a faster and FREE encoder that i can use?
thanks in advance
Zworg2
Results 1 to 10 of 10
14hrs looks about right with your specs.
so is there a non-free encoder that is easy to use for newbie that is likely to process significantly faster (therefore worht investment) than TMPGEncOriginally Posted by bugster
mostof the guides use TMPGEnc or CCE (which i cant seemto get on with)
thanks in advacne
Zworg2 -
Canopus Procoder and Mainconcept MPEG Encoder are both very good encoders. Canopus is probably easier to use between the two but Mainconcept is faster.
Are you are using the 2-pass encoding (VBR)? I was doing that as well, then I read this guide: https://www.videohelp.com/forum/userguides/186739.phpOriginally Posted by zworg2
It's amazing. I use the bitrate calculator and then use CBR encoding with the corresponding bitrate from the calculator, and the results are superb!! My TMPGEnc times are also down to between 3-4 hours
I've also started to frameserve the movie I'm converting from Virtualdub, even if TMPGEnc doesn't need it. For some reason, the movies seem to encode faster when they are frameserved from Virtualdub for me. Maybe it's just an illusion though! -
I suspect i will give Mainconcept a go.Originally Posted by teegee420
THANK YOU
Zworg2 -
No i'm using CBROriginally Posted by gkolleng
Yep i using a bitrate calc, using a value lower than it suggestsOriginally Posted by gkolleng
Weird, but as above i think i gonna try mainconcept, the trial version is quoting a 2-3 hour encoding for same file!
I dont fully understand frameserving yet so i dont do it.....maybe next thing for me to look into and learn about.Originally Posted by gkolleng
thank you
Zworg2
multiple processing, or 1-at-a-time?
By coyote2 in forum EditingReplies: 4Last Post: 15th Oct 2011, 18:52 -
TMPGEnc Problem - navigating one frame at a time
By ereiamjh in forum Video ConversionReplies: 4Last Post: 28th Jul 2010, 09:55 -
TMPGEnc Plus not processing to specified parameters!
By Thommers in forum Video ConversionReplies: 5Last Post: 16th Dec 2009, 01:21 -
Will this cut my processing time in half?
By jsbenson in forum ComputerReplies: 7Last Post: 17th Oct 2009, 22:45 -
problems with avc to mpeg-2 in tmpgenc xpress 4.0 - more than 3x run time?
By NoFace in forum Video ConversionReplies: 3Last Post: 18th May 2008, 22:01
