Hi, I was trying to convert a movie (asf) to mpg file so I can burn it on a CDR. But, after I converted the movie, the audio is all messed up. It will play for a sec, then mute for a few, play again, and mute again, and on, and on...I don't know if that's what u call "out of sync". If anyone knows how to fix that, please let me know.
Thank You=)
Try demuxing the audio and muxing it back together again. Maybe the program you're using as well as your computer, can't do it all in one shot.
If that doesn't work, try converting it to DivX or another AVI format first, then back to MPEG. You may get some quality loss, but most ASF videos out there don't have much to lose anyway.
Hope this helps.
Multiavchd menu messed up
By jaydev2005 in forum Authoring (Blu-ray)Replies: 3Last Post: 21st Jul 2011, 15:23 -
Audio messed up when burning .mpeg on DVD +R
By greenda4 in forum AudioReplies: 16Last Post: 19th Nov 2008, 15:52 -
my DVD and HDD messed up
By goodguyswearblack9 in forum DVD RippingReplies: 8Last Post: 20th Apr 2008, 02:11 -
timecode messed up
By snafubaby in forum EditingReplies: 4Last Post: 20th Sep 2007, 05:00 -
wmp11, colors messed up
By nfl2k2 in forum Software PlayingReplies: 2Last Post: 20th Jun 2007, 12:44
