yo...
when im converting 2 mpeg (vcd) (adding subtitles) from avi my movie is about 930mb n i was wondering how can i reduce this size?
would i b able 2 exctract the audio (reduce the bitrate of it from 244 2 like 128 or summin ) from the avi n then when converting 2 mpeg....is that possible? if so how can it b done?
will i still b able 2 play the vcd in my stand alone player?
im using virtual dub n tmpgenc
thanks heaps...
Results 1 to 20 of 20
Lower your bitrate setting when you encode, it's the last screen of the project wizard.
"Art is making something out of nothing and selling it." - Frank Zappa -
wat the audio???
i had 2 extract the audio cos vdub said it has some errors so i extracted it 2 wav
btw the last screen ins greyed out .. unable 2 change it -
Use a bitrate calculator.
100mb and a VCD???? no way!
if you crunch it down a lot you might get around 750mb - and it would probably look crap
Ok Ok - well actually if you unlock the TMPEG template and put in a really low bitrate you might get down to around 100MB but the image would probably look like about 32 large moving dots and that's about it
Some things are too large to compress that much with MPEG1 -
Lowering the audio bitrate to 128 will help a bit but the video bitrate also has to be lowered. If you try to do that and still keep the vcd in spec it will probably not look very good.
Time is an important factor when trying to fit a movie on 1 cd (<800mb). How long is the video? If it's much longer than 60 minutes then you might want to try to make a non standard (x)vcd. Look at the templates in the tool section. You will have to try one to see if your standalone player will accept those. There may be some info in the DVD player section of the site. -
By 100Mb, no TO 100Mb I assume you mean.Originally Posted by krayzie
You have to set it encode as MPEG-1 Video-CD (non-standard). This is on the system tab of the settings dialog. Not sure if it can be changed in the wizard as I never use it! -
yes i mean 924-100=824 approx....
i have set it 2 vcd non standard
its about 1hr n 1/2
ar 128 bitare its 924mb
any ideas???
xvid cant play on standalone players can it? -
Unless you are willing to cut out credits or some other info then, like I said before, get the tmpgenc templates from the tools section. Try kwag's and you will have no trouble getting the file size of a 90 minute video down to less than 800mb. The only way to know for sure if your player accepts those is to try one disc yourself although as I said before there may be some info on your player in the "DVD Players" section of this site which may tell you if it can play (x)vcds.
I used to use kwag templates but my Apex player needed my ntsc video to be 29.97 instead of the (kwag) recommended 23.97 fps. I just adjusted the fps to 29.97 with no pulldown (up) so they would play on my player. Even with the larger filesize I still had no problems fitting a 90 minute movie on 1 disc.
Although I had reasonable success at the time, the quality is highly subjective and is dependant on source so I must warn you that some people don't like the templates. At your request, I'm only providing you with an option to consider. You may find them to your liking.
Reduce MPEG-2 filesize without losing too much quality?
By yic17 in forum Video ConversionReplies: 10Last Post: 26th Oct 2012, 09:02 -
how can I reduce bitrate and frame rate when converting avi to mpeg-2(dvd)?
By jasoothai in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2011, 04:42 -
DVD Video Image Oversized Question
By JerryRecords in forum Video ConversionReplies: 3Last Post: 21st Dec 2008, 12:14 -
reduce bitrate of mpeg file
By bradlewa2 in forum Newbie / General discussionsReplies: 10Last Post: 24th Apr 2008, 10:32 -
Oversized video file...
By Felo in forum Video ConversionReplies: 3Last Post: 18th Jan 2008, 03:14
