If I wanted to create a DVD that contains links to files in other subdirectories, what is the syntax for designating a root or point of origin like a regular link to a file stored on a local disk, that will be universally recognized regardless of what machine I put the disc in, and regardless of drive letter assigned?
Example:
Say I have an html web layout, with links to graphics stored in subdirectories on the DVD. I can make all my paths read E:\whatever\folder\etc... and that works fine on this particular machine, but what about another machine with the DVD drive assigned a different letter?
What is the proper way of doing this?
edit: This is not a DVD-Video project....data only.
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
blah
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
I know that working from a command prompt or in DOS you can just specify a path with a leading "\" to mean the root of the current disk.
But if you're working with HTML files the proper way is to use relative links for everything. Instead of specifying href="file:/// ..." you just use href="subdir1/subdir2/file1.html". Use ".." to mean the enclosing directory.A man without a woman is like a statue without pigeons. -
the path would then be
image/pic.jpg
This assumes of course the html file is in the rot of the disk.
Note the / and NOT a \
html code should be / always.
VOB2MPG and network paths
By kfealz in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 5th Jan 2010, 20:21 -
Using Super - can paths be changed?
By Will_Annand in forum Video ConversionReplies: 3Last Post: 4th Jun 2008, 14:24 -
Moving Paths/Keying Help
By Trunkz Jr in forum EditingReplies: 6Last Post: 10th Apr 2008, 19:01 -
audio take different paths in PS2 and computer?
By willmoodom in forum AudioReplies: 4Last Post: 17th Sep 2007, 18:39
