I have made some nice animated titles with Cool 3D, and was wondering if there is anyway to incorporate them into Pinnacle Studio 8 as transparent background titles?
Studio doesn't seem to like animated gif files. Is it possible to overlay two video files?
On a related note, if the answer is that it can't be done, what software could do this? I also have an old version of Ulead VideoStudio - can I import Cool 3D files into Videostudio?
Thanks!
I haven't tried this with Studio 8, but I have used it a lot with VideoStudio 7.
In Cool 3D, save the animation as a series of TGA images with a transparent background (it helps to save these to a separate folder as there will be on file for each frame -- e.g., filename0001.tga, filename0002.tga, etc. -- so a 10 second animation at 29.97 frames/sec = 300 files). Note: depending the coplexity of the animation, duration, quality settings, and speed of your PC, it can take quite a while to save all the images.
In Video Studio, add the series of files to the overlay track with a duration of 1 frame set for each file (you can do this in one step in VS7 -- in timeline mode, select the overlay track and then click on the folder icon in the lower left hand corner -- using the file selector that comes up, select all the files in order, change the duration to 0 sec, 1 frame and click ok).
This may also work in Studio 8 using the title track as the overlay track, but like I said. I haven't tried it. -
Yes you can, I made a title with animated fire text. You will need HFX pro so you can use the chroma plugin. Create an AVI file with ulead cool 3D using a blue back ground, place on the time line and put your hfx transition down..
Good Luck
Sample I did a while back -
Thanks for the encouraging words, at least I know it CAN be done.
I do have HFX Pro (version 4.6.1)test but don't know how to use the chroma plugin. I tried searching the forums, but couldn't find a guide on how to use this exactly.
When I open the HFX Editor, I don't see a chroma key option - and when I select plugins, I get a message saying there are no plugins available for the selected item.
Any hints?
Thanks,
Icarus
Avid Studio vs. Sony Vegas Pro/Studio
By HoosierGuy in forum EditingReplies: 12Last Post: 8th Dec 2011, 20:06 -
Sony Vegas Movie Studio/DVD Architect Studio
By DJL82 in forum EditingReplies: 8Last Post: 1st Feb 2008, 15:14 -
PINNACLE STUDIO 11 vs. SONY VEGAS MOVIE STUDIO 8
By coody in forum Capturing and VCRReplies: 4Last Post: 26th Nov 2007, 18:53 -
I just listened to my first podcast - cool!
By yoda313 in forum Off topicReplies: 3Last Post: 26th Sep 2007, 16:17 -
Studio DC10 Plus analog Card, XP and Studio 10 capture split in half
By jackylhome in forum Capturing and VCRReplies: 0Last Post: 22nd May 2007, 22:48
