I'm having an issue with explorer.exe shooting up to 100% cpu utilization and staying there whenever I left or right click .mpg files. It stays up whether or not I play the file, delete it or deselect it. If I cancel the explorer.exe task and restart it, it stops, but this is quite a nuisance to have to do dozens of times a day. Does anyone know whats causing this and how to fix it? It only happens with .mpg files.
Results 1 to 12 of 12
explorer.exe is windows. when the performance goes up to 100% that means that all of your processor is being used by windows. what software are you using to play the mpg files? it seems like windows is trying to load that application but it cant. try redownloading that program.
I usually use media player or realmagics player, though I don't think it matters. Just simply selecting the file by either left (or right) clicking it causes the spike in explorer, even before any player is started.
Experiencing the same thing. Got both Win2003 and XP dual boot. Locks up explorer.exe in win2003 but same file plays in XP. Just right clicking causes this problem...
me too, running on 2000. i don't get what's happening with it, as explorer isn't actually DOING anything.
After further investigation I found that it must be F-Prot RealTime Protector software causing this. If I disable this it runs fine.
The issue could be related to this problem. It could be that Explorer is attempting to read the specs and/or generate a thumbnail. The reg fix in the thread I linked might solve the problem. Just a thought.
Well might not be the same fault cause we have.hmm, but i use AVG not f-prot.
Have you tried to close all non essential running tasks before trying to open the file? -
well it's very erratic, can be a few eeks between cases of it, kinda hard to track down to a specific problem
Sounds to me like you all got the same porn movie off of P2P.
Have you all patched you WM9 yet? This porn movie has a virus in it
My mpg's are recorded from DVB-S sat card. I doesn't happen with all recordings so difficult to say why it happens. It seems F-Prot is the cause in my case.
Certain MKV file crashing explorer.exe
By liuzhen in forum Video ConversionReplies: 4Last Post: 27th Jun 2012, 07:32 -
explorer.exe high memory usage while trying to load ass/ssa subtitles
By Nightroad in forum SubtitleReplies: 2Last Post: 17th Jan 2012, 18:36 -
How do you stop Explorer from locking video files?
By Djard in forum Newbie / General discussionsReplies: 2Last Post: 2nd May 2011, 02:49 -
AVI did with Huffyuv codec cause crash in explorer.exe
By PalmTX in forum Capturing and VCRReplies: 5Last Post: 15th Feb 2008, 18:09 -
explorer.exe / drwtson32.exe keeps closing
By coolcoates in forum ComputerReplies: 7Last Post: 28th Nov 2007, 09:42
