Hi Guys,
I have a VCD which seems to be bad.. I try to copy it with Roxio.. But it does not copy. I tried using VCDGear. But it stops at 1%...
Is there any other good free software tht I can use to copy a VCD to VCD..
Thanks in advance
You say the VCD seems to be bad. What does that mean ?
Will it play on your PC or DVD Player ?
If it will not work then you cannot expect to copy it. -
Thanks for that quick response friend..
yes, it works on DVD player.> But I can not copy it
RipBot264 - Need help bad
By minks in forum Video ConversionReplies: 7Last Post: 21st Dec 2010, 20:54 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
my new pc......not bad...
By khalid81 in forum ComputerReplies: 4Last Post: 29th Sep 2009, 16:41 -
Bad motherboard or bad CPU?
By videohalp in forum ComputerReplies: 11Last Post: 9th Jul 2008, 10:07 -
Bad encoding? Bad installation
By lo-q in forum ffmpegX general discussionReplies: 2Last Post: 22nd Sep 2007, 19:45
