If i create a VCD with a mpg with a very high bitrate
and i create the same movie on a svcd with a lower bitrate
Is it possible that the vcd will be a movie with better quality that the svcd ?
I have found that if you create a VCD and a SVCD with the same bitrate, the VCD is better quality. Why ? Because VCD is using say 1500kbps on a 352x288 screen whereas SVCD has to cover 720x576. TV can blow up 352x288 very well and I guarantee it will result in a better picture.
If in doubt, Google it. -
Originally Posted by bambam
A bit-starved SVCD (say 1400 Kbps or lower) is terrible and a VCD at that rate could be better looking. Now say you go up to 1900 or higher, an SVCD will be much better than a VCD at that rate. That assumes a good quality source with a resolution nearer to SVCD (480x480) than VCD (352x240)."Art is making something out of nothing and selling it." - Frank Zappa -
This is a point many people get confused about. Here's the bottomline, SVCD is superior to VCD. HOWEVER, what most people are asking about is xVCD vs xSVCD (ie. non-standard).
At the same bitrate and resolution MPEG1 looks the same as MPEG2. So if you encode a 352x480 2000kbit/s video to MPEG1 and author as an xVCD, or to MPEG2 and author as an xSVCD/xCVD, the quaility will be the same.
It use to be that a lot of people would recommend making xVCDs as they were more supported by most standalones. These days it's a little more hit and miss, but still generally true.
Another thing to consider is that MPEG1 doesn't supported interlaced source material.
901102 - best VCD quality
By hamidi2 in forum Video ConversionReplies: 32Last Post: 26th Aug 2018, 18:49 -
Convert .avi movie files to vcd or dvd without loosing picture quality
By akakiami in forum Video ConversionReplies: 8Last Post: 8th May 2010, 17:01 -
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 16:56 -
Movie quality for VCD
By dilanalex in forum Newbie / General discussionsReplies: 12Last Post: 21st Apr 2009, 01:42 -
How to add Watermark to VCD MPEG1 without Quality Loss?
By shebi in forum Authoring (VCD/SVCD)Replies: 3Last Post: 15th Apr 2009, 13:13
