I wanted to get some video from a VCD I have so I used the VCD to MPG article on this site. The only problem is that when you get to the part of extracting the data to filter only M2F2 Mpeg frames you can't type a name (filename.mpg) to save it under. It only allows you to pick the destination where the DAT files will be saved.
Does anyone know how to remedy this, or possibly another way to convert DAT files to MPG?
If everything is infinite then nothing is definite.
You should be able to - you have to change the file name to .mpg then save .
It doesn't give you that option in this version, just the destination folder selection. I did find a way however, extract the DAT files, open them in Windows Media Player, and save them as .mpg. Thanks for the help.
If everything is infinite then nothing is definite. -
I've used both the lkvcdxrip and vcdxrip programs to do this all the time
with no problems what so ever.
Sabro
DAT/MPG to VOB/MKV?
By coxanhvn in forum Newbie / General discussionsReplies: 2Last Post: 30th Jan 2011, 06:21 -
Ripping Karaoke DVD to VCD (.DAT) (Mpeg1)
By Nhuii in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 21st Aug 2010, 00:01 -
Need VCD DAT video splitter Without Reconversion?
By kitharass in forum EditingReplies: 7Last Post: 16th Feb 2010, 14:37 -
VCD dat files
By mayflower in forum Newbie / General discussionsReplies: 1Last Post: 18th Mar 2009, 07:50
