Installed FFDShow. Great I thought, finally get rid of all the codec errors.
Everything is green!
Uninstall, everything is normal.
Now what do I do?
Cheers, Jim
My DVDLab Guides -
I have downloaded ffdshow, and just plain did not like it.
I am only guessing, but it may be a possibility that you have clashing codecs, hacing too many installed at once can lead to all sorts of weird and wonderful problems, nearly all resolveable by de-installing.
just a suggestion, but try de-installing any codecs or codec packs that you have that you dont use or need.
Zworg2 -
Thanks, that was my next move, to uninstall everything, then try it again.
So many codecs seem buried, and uninstallable, might have to do it manually, unless someone know's an easier way.Cheers, Jim
My DVDLab Guides -
I had a problem with too many codecs installed once and I just decided to scrap Windows completely and start over.
This technique isn't for everybody however, but it did work for me."There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
Some DVD works, some other don't
By boraborasands in forum Authoring (DVD)Replies: 3Last Post: 18th Dec 2010, 11:06 -
One SRT works, the others don't
By ebay in forum SubtitleReplies: 1Last Post: 24th Jun 2010, 16:48 -
trying to fix a scratched dvd, works on pc but not player...
By extent in forum Authoring (DVD)Replies: 3Last Post: 28th Feb 2010, 10:02 -
VOB2MPG WORKS GREAT PLUS HANDBRAKE FOR PS3 5.1 sound fix
By JordonB in forum DVD RippingReplies: 10Last Post: 7th Sep 2009, 22:55 -
I don't know how to call this distorsion... How to fix it?
By oldie__ in forum RestorationReplies: 10Last Post: 3rd Feb 2009, 07:00
