I had this DVD reader program (I forget the name of the program) that would always ask to install it everytime I put in a DVD. Being extremely annoyed I did a search on the reader in the registry and deleted all the keys that were related to the DVD reader. Now, anytime I put in a DVD an error dialogue box comes up:
Title: "Desktop"
"Access to the specified device, path, or file is denied."
I can just click "OK" and have no problems afterward, but it's annoying to have a dialogue box everytime I put in a DVD.
Does anyone know how to fix this?
Derrill
Depends on your OS. In Xp you can go to Control Panel>Folder Options>File Types and set what you want the default for DVD videos to be. W98 is probably similar. It sounds like your file associations is messed up. If you are not very familiar with the registry, you should leave it alone. You can easily cause permanent problems that can only be fixed by a system reinstall. With XP, use Add/Remove to remove a program if it doesn't have a uninstall. Registry is the last thing to try.
DVD Pioneer DV310 - enabling region free
By p_uriel in forum DVD & Blu-ray PlayersReplies: 8Last Post: 30th Jan 2011, 20:10 -
Help with cycling through/disabling soft subs from mkv->DVD conversion
By herbster in forum SubtitleReplies: 1Last Post: 24th Nov 2009, 02:44 -
Media Classic Player: Enabling Closed Captioning and Last Scene: for DVD
By hollowman in forum Software PlayingReplies: 1Last Post: 22nd Sep 2007, 07:29 -
Autorun Precedence - DVD & Autorun on the same disc
By SCDVD in forum Newbie / General discussionsReplies: 1Last Post: 15th Aug 2007, 21:26 -
DivX on DVD Autorun Software
By Burgos in forum Software PlayingReplies: 0Last Post: 31st May 2007, 10:13
