Hi
Need some help guys.
Have an import dvd film from the US - Unfortunately it is faulted approx 80% of the way through - none of the rippers can read from the dvd
How can i salvage most of the film - extract th vob files and rebuild a dvd from those extracted files and is it possible to pick up the film files after the fault on the vob
I sense there iis away round using some formof clip method - but with which prog
is there anyprog that reads the vob files and then redirect hem to form a dvd
please advise
kriffendorf@aol.com
Try TMPGEnc DVD Author. It'll convert the DVD to MPEG-2 files that you can then use to create a new DVD. Not sure if it'll be able to read *after* the bad spot tho.
Try something that works.
Use DVDDecryptor, tell it to ignore errors after 2 re-tries. Clean the DVD with the toothpaste method (tepid water, toothpaste, and your finger, in motion around the DVD, not edge-center, rinse and pat dry). Rip the disk. It can take awhile to get through the rrors. Hopefully you will just have a hard jump at the errors, and the remaining 19% should be fine.
I have salvaged several kids movies this way, with only a few hiccups in spots for a badly damaged DVD.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
I have salvaged DVD's using Carnuba Wax. (Do not use liquid wax of any kind!!!) I use an old pioneer 2x DVD when doing this, just in case but i'v ben doing it for 2 years with no problems.
I personally use Turtle Wax Carnuba Paste.
and apply a very thin film to the bad spots
then buff these areas out I use a dremal on low speed with a polising bit
also when buffing by hand heavy felt seems to work.
Is there any chance to retrieve something from corrupted MP4 ?
By jazzzy in forum Newbie / General discussionsReplies: 4Last Post: 2nd Apr 2011, 01:32 -
I want to know if it would be possible to retrieve the video from the DVD-r
By robinei in forum Newbie / General discussionsReplies: 5Last Post: 17th Sep 2009, 00:11 -
Retrieve files from missing partition
By vegasarian in forum Newbie / General discussionsReplies: 13Last Post: 29th Apr 2009, 18:55 -
How to retrieve data off a bad drive?
By DarrellS in forum ComputerReplies: 16Last Post: 23rd May 2008, 08:38 -
AVI Roxio retrieve CD error
By pabloj240 in forum Newbie / General discussionsReplies: 4Last Post: 17th Aug 2007, 18:59
