Just wondering if anyone had the Full version of MF 3 and is it better then two and how do they like it. I hear the editing is better then MF 2...
YB![]()
i have it and it's a lot different. many improvements, and you can burn anything you want.....probably i will give up on nero soon....
and it has also dvd picture show bild-in.......
try it, you'll like it -
lenti_75,
Can you edit out scenes or say commercials in a TV Show that you capture? MF 2 would only let you cut the beg and end off unless you wanted to make sub-menus..Thanks YB -
When you install MF 3 does it write over MF 2 just curious??
YB
Ulead DVD Movie Factory 6 Plus
By orientaldragon in forum Newbie / General discussionsReplies: 8Last Post: 2nd Apr 2011, 08:48 -
Movie Factory 6+ with HD-DVD Plugin
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 25th Oct 2010, 11:20 -
alternative to ulead movie factory
By marlo in forum Newbie / General discussionsReplies: 1Last Post: 15th Sep 2008, 03:48 -
Ulead Movie Factory 6 plus
By ictaylor in forum Newbie / General discussionsReplies: 1Last Post: 10th Jul 2007, 02:20 -
Ulead DVD Movie Factory 5 Plus Help
By sootylfc in forum Authoring (DVD)Replies: 3Last Post: 21st May 2007, 18:20
