Does anyone know if they sell a Multisystem VCR with Time Base Corrector (TBC)? I know I can get an external one but I need to know if they have it builted in.
Results 1 to 12 of 12
Don't know about that, but here's an interesting little box that would allow you to do the same thing with your existing VCR:
http://www.planetomni.com/CONV_TNLB_tr-10sp_DTL.shtml -
Originally Posted by Kevin abq
Thanks -
Tommyoz,
Sorry I couldn't help. I've seen loads of multisystem VCRs, but not with the features you mentioned. Good luck to you. -
Here is my research so far... I've been looking into the same thing. Looks like so far the best one is the JVC HR-S8965. But you would have to convert power since it is is not auto switchable. My listing below is somewhat disorganized, but it should still be of help. I was first looking into getting just a PAL VCR, then multi, then multi with TBC (seen at the bottom).
HITACHI VT-695 6 HEAD $139
Hitachi VT-FX695E 6 head VCR $119 (bombay electronics)
Hitachi VT-M748E 4 Head multisystem VCR $139
HITACHI VT-M748E 4 Head VCR $114 good not sure if it is stereo
JVC HRJ-491 4 HEAD $119
JVC HRJ-72MS 6 HEAD $139
JVC HR-J71MS 6 Head Hi-Fi VCR $134 dual voltage? (bombayelectronics)
JVC HR-J82MS 6 Head Hi-Fi VCR $119
JVC HR-J71MS 6 Head Hi-Fi VCR $119 (Worldwide electronics)
- Wide Quality for wide screen 16:9 and 4:3 TVs (this feature makes me want this one)
PANASONIC HV-60 6 HEAD $179
PANASONIC MV-40 4 HEAD $149
Panasonic NV-SJ500 4 Head Multisystem VCR $149
Panasonic NV-SJ530 4 Head VCR $134
SHARP VH-990 6 HEAD VC with PAL & NTSC $219
SHARP VC-AA550 4 Head VCR $119
Sony SLV-ED818 HIFI Multisystem VCR 6 Head $189
Sony SLV-ED939 6 Head MultiSystem VCR $169 (bombayelectronics)
SONY SLV-ED 828 6 Head Hi-Fi VCR $164 **I am leaning towards this one
- emphasis on picture quality. Seems built like a tank.
Toshiba VE-60 6 head $139
TOSHIBA Deluxe Multi System VCR 6 Head $179
Questions:
mono/stereo
switching power supply
plays PAL
outputs PAL
JVC VCR with TBC
HR-S9911 $349 4mb TBC NTSC
HR-S9911U $399 4mb TBC (PAL/NTSC? What is the 'U' for?)
HR-S7955 *** 2mb TBC, PAL, NTSC playback over PAL, 16x9 (switchable powersupply?)
HR-S7965 *** (newer model?) 2mb TBC, PAL, NTSC playback over PAL, 16x9, powersupply not switchable
HR-S8965 2mb TBC, PAL, NTSC playback over PAL, 16x9, powersupply not switchable
Darryl -
So you did find some. I'll have to look into those. Damn!! I couldn't find anything. I actually emailed one supplier and asked them, but they never responded. I can't understand why companies don't respond when they are in the business to sell. I guess that's another subject though.
Thanks, -
dphirschler,
So close but yet so far. Those VCR's are pal. I am looking for NTSC VCR that will convert to Pal with TBC. -
Are you talking about the JVC (at the bottom)? It's a PAL VCR, true. But it will play the NTSC tapes and output PAL. Isn't that what you want? I downloaded a PDF of the instruction manual for a couple of those JVCs. That's the understanding I got from reading the instruction manual.
Darryl -
Originally Posted by dphirschler
I'm in the US too. As long as your capture card can capture PAL, then I believe you won't have a problem. I assumed that was what you wanted since you posted in the 'capture' forum.
I forget if it was a Samsung or a Sharp, but it came up at the top of my searches for "conversion" VCRs. It was quite a bit more though. So much that I didn't even list it in my research ($800 or so? I forget). I wonder if it'd be cheaper to use a PC with Descaler to convert PAL to NTSC.
Darryl -
It's best to get a PAL VCR and separate NTSC VCR. If I had it to do over again, I'd never have gotten my worldiwde unit. It's a pain in the butt, and I use it mostly in PAL mode, as the conversion sucks.
Confused: Why a VCR with TBC if separate TBC needed anyway?
By tluxon in forum RestorationReplies: 211Last Post: 2nd Aug 2013, 19:31 -
TBC suggestions: TBC-1000, AVT-8710, ADVC-300, TV1-TBC, or TV1-TBC-GL
By m27315 in forum RestorationReplies: 16Last Post: 24th Mar 2010, 01:36 -
PAL Video Cassette Recorder or [Multisystem VCR] for PAL->NTSC playback
By quantass in forum Newbie / General discussionsReplies: 10Last Post: 12th Dec 2008, 13:47 -
VCR with TBC
By dumbidiot in forum RestorationReplies: 39Last Post: 20th Jan 2008, 12:46 -
panasonic VCR tbc + external tbc - any use ?
By abbymat in forum RestorationReplies: 13Last Post: 15th Aug 2007, 08:29
