  1. Sorry if this has been answered before but I could not find anything on this... When I copy a movie with Recode and remove unwanted audio files (like DTS and Dolby 2) and keep the one I want (Dolby 5.1) and play it back on my standalone, the audio files are completely removed. What I mean is that if you try and change the audio while the movie is playing or in the menu it won't let you, the default will always be the one you picked (Dolby 5.1). Which is great for me. But with CloneDVD2 I've noticed that if you remove the audio files you don't want and then watch it on your player, the other audios are still selectable, but if you choose them they won't work. So if you go in the menu and accidentaly pick DTS for example, you'll have a movie with no audio. My question is, what can I do to make the audios un-selectable? So it always defaults to the audio I kept. Hope someone understands and can help. TIA.
  2. Member wulf109's Avatar
    Jul 2002
    CloneDVD2 copies the original ifo files to the copy. That means the DVD player sees all the audio streams even if they were deleted. Recode and DVD95COPY however re-create the ifo files to reflect only the streams you kept.
  3. Thank you both for the info.
