I have a 9600U. I seem to remember someone here mentioning that there's a way to do manual tracking on this VCR. I'm asking because the JVC appears to have tracking problems with this one tape while two other non-JVC VCRs don't have the same problem.
TIA
I have a 9500U, so I think it will work for yours as well. On the unit, press the + and - channel buttons simultaneously for a couple of seconds. Then you can use the same buttons or the ones on your remote to adjust the tracking. I usually do the manual adjust for most tapes. The picture is usually OK, but the audio switches between "stereo" and "normal". Hope this helps.
wwaag -
Hold channel up/down at the same time on the unit. It disengages auto. Don't do it longer than pressing time plus an instant (not a full or even half second .. more like a quarter or eighth). Holding it makes it go on and off rapdily, not good for it.
This is needed once in a while.Want my help? Ask here! (not via PM!)
Ugh. I think I'll just use my Toshiba VCR which tracks automatically and perfectly. But thanks for the info everybody!Originally Posted by lordsmurf
The -/+ ch buttons are good for adjusting still frames as well. It works independent of the regular tracking.
"Knowledge makes a man unfit to be a slave."
Frederick Douglass
Looking for info re three old VCRs - two JVC and one Fisher
By wiseant in forum Capturing and VCRReplies: 2Last Post: 23rd Jul 2024, 13:01 -
VCRs with separate video/audio tracking?
By Relayerman in forum RestorationReplies: 7Last Post: 16th Oct 2014, 05:47 -
Tracking problem with JVC camcorder.
By The-Geek in forum Newbie / General discussionsReplies: 0Last Post: 28th Aug 2010, 12:23 -
Anyone here use a JVC HR-S7000-U SVHS for capturing?
By rijir2001 in forum Capturing and VCRReplies: 13Last Post: 12th Oct 2008, 23:45 -
JVC SR-S365U SVHS unit
By barkingcat in forum Capturing and VCRReplies: 4Last Post: 6th Feb 2008, 15:04
