After successfully converting and burning numerous videos I've come across one with a peculiar problem. When played on my standalone player the picture is squeezed into the upper left corner taking up about a quarter of the screen. I looked through the FACs and tried searching the forums and didn't find anything on this.
Anyone know how to fix this?
What encoder are you using?
If tmpgenc try changing your arrange method, a good way to find out what is causing it is to make a bunch of small mpegs all with differnt options and see which one does do it and doesnt do it. -
Also check resolutions to see if they are standard spec, had this prob when my resolution were not standard specs.
Sorry, I should have expanded on that. I'm using Tmpgenc and have tried all the arrange methods. The orginal res is 544 X 304. Any clues?
no what's your ENCODING res that you are doing..as long as you have "full screen (keep aspect ratio)" you should be fine regardless...check you output res, make sure its standard spec works first b4 you try deviateing from it.
Kdiddy, yep that was it. I forgot I was trying to keep the original res intact. I did use the "full screen (keep aspect ratio) arrange method, but that didn't help. I set the output res to standard and it worked. Thanks for the help.
PC picture is off center!!
By Kipster1203 in forum DVB / IPTVReplies: 10Last Post: 2nd Feb 2013, 00:07 -
PC to entertainment center
By bbrown in forum Newbie / General discussionsReplies: 3Last Post: 22nd Sep 2008, 19:34 -
have just the center of the video...
By keesio in forum EditingReplies: 1Last Post: 6th Sep 2008, 23:58 -
Media center video won't play on standalone dvd player
By larrym in forum Newbie / General discussionsReplies: 2Last Post: 7th Jun 2008, 22:04 -
Sharing TV - 1 Vista Media Center Server to Vista Media Center PC
By JBredensteiner in forum Media Center PC / MediaCentersReplies: 8Last Post: 14th Jul 2007, 01:33
