  1. Hey all,
    I'm a little confused by and also curious about the fact that two guides I read for converting Divx/Xvid avi's (in my case with mp3 audio) to DVD mpeg using TmpegEnc give a conversion time of 2-5 hours. One of them was with an XP2400+ system.
    I have an XP2200+ system and my conversion took 15hours!
    is there something I've done wrong? have I setup something incorrectly? or is it common for the program to take this long
    Ell ~_^
  2. Member holistic's Avatar
    May 2001
    here & there
    There is NO standard. In order to compare you must use identical settings and source file.
    A 5 hour encode for one may take 15 IF :
    - filters are used
    - 2 pass vbr instead of CQ
    - audio done seperate
    - motion search
    - crop / resize .......
  3. Add to that
    -multitasking
    -total free RAM
    -bus speed
    -hard drive speed
    -any number of other different variables
    Cheers, Jim
    My DVDLab Guides
