I had a question....has anyone tried to do a test capture from the Sony TRV-350 or a similar D8 camera from the AV jacks direct to DV to their computer via the passthrough? Reason I am asking is that I wanted to know if it will capture without losing sync in the audio and video. I did try a test capture over the weekend using the laptop, but unfortuantely it dropped frames seconds after it started (did the same thing when i played a D8 tapes for a DV test capture also) so I will have to wait until I build my new system to test it out (ordered the rest of the parts so they will be arriving later this week!). My old laptop really isnt capable of capturing video so I will have to wait until then. While it may capture fine starting out, its usually after maybe like 10 minutes or so when most video tends to go out of sync. If this works it could be a viable soulution from the Canopus ADVC-100. Thanks.
VTM
I have the staff of power, now it's up to me to use it to its full potential to command my life and be successful.
I am using my Sony D8 TRV120 (european model) as a DV passtrough.
I have it permanently connected to my VCR and use it to record from TV and VHS with great results. Never have encountered audio sync issue's with it.
(Even when there are severe dropouts or total signal loss)
The good thing is it stabilizes the videosignal which helps a lot to make good captures.
delete
By deuce8pro in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 26th Jul 2010, 14:50 -
Sony TRV 138 or TRV 350: do these camcorders have "pass through"?
By tadd5181 in forum Video ConversionReplies: 1Last Post: 24th Apr 2010, 19:38 -
Sony DCR-TRV-20 external mic impedance matching
By Larry Larson in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 21st Sep 2009, 15:54 -
Sony TRV - digital, but record onto Hi8 tapes?
By OM2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 1st Jun 2009, 13:07 -
Transferring video from Sony DCR TRV 285E to PC ...need dv sample
By ganduman in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 12th Mar 2009, 10:20
