I got 50 Riteks G04 DVD-R with the purple top cover, they seem to burn ok at 4X and at 2X, but after when watching the movie about 40min or 1hr into the movie it just seems to frezze up.
I burned a movie on to Verbatim DVD-RW and that played fine, then burned the same movie on to the Ritek watched it and it just frezzes 48min in to the movie.
Tryed 4 different movies at 4X & 2X and they all stuff up.
I use a LG 4040B with A302 Firmware
Ripping with DVD Decrypyer 3.1.9.0 or DVD Shrink 3.1
Burning with Nero 6.3.0.2 or BurnatOnce
The Ritek G04 Media Info
Region information - N/A not a DVD-VIDEO
Media code/Manufacturer ID - RITEKG04
Format Capacity - Not Formatted
Free Blocks - 411107328
Free Capacity - 4.38GB(4.71GB)
Book Type - DVD-R
Media Type - DVD-R
Media Id Code Speed - 4.0x 5540KBps
Available Write Descriptor - CLV 4.0x 5540KBps
Available Write Descriptor - CLV 2.0x 2770KBps
Write Strategy Speed - 4.0x 5540KBps
2x Speed OPC beta - 08
2x Speed OPC power - 12
2x Write Strategy field 1 - 11 86 67 80
2x Write Strategy field 2 - 88 80 00 00 00 00
4x Speed OPC beta - 06
4x Speed OPC power - 19
4x Write Strategy field 1 - 0A 0B 09 01
4x Write Strategy field 2 - 99 05 0C 0B
4x Write Strategy field 3 - 00 00 00 00
4x Speed OPC beta multi-pulse - 04
4x Speed OPC power multi-pulse - 1D
4x Write Strategy field 4 - 18 A8 88 85
4x Write Strategy field 5 - 89 AC 88 80 00 00
4x Write Strategy field 6 - 00 00 D0 00 00
Data area starting sector - 30000h
Linear Density - 0.267um/bit
Track Density - 0.74um/track
Number of Layers - 1
The Media Code
00 6A 00 00 01 40 C1 FD 9E D8 52 00 02 76 0E 14 .j...@....R..v..
88 9A 80 00 03 52 49 54 45 4B 47 00 04 30 34 00 .....RITEKG..04.
00 00 00 00 05 88 80 00 00 00 02 00 06 08 12 11 ................
Are these discs bad or does my burner just not like them.
Results 1 to 11 of 11
i have the same problem and had the same exact problem with sandy yang - some work and some dont -
i heard it might be with dvdshrink - try compressing it an extra 200 - 300 mb so the die doesnt go all the way to the end - also i heard don't use region free in dvdshrink , use region 1 only -
i am actually about to test this method out and see if it works right now with my sandy yang (cheap media) disc since my test pack of 2 Riteks G04 are now gone (1 froze and the other worked fine) -
thank you!!!!!!!!!!!!!!!!!!!!!!!!!!
Version 3.1.6 - 23 Feb 2004
Fixed bug which caused occasional skipping/freezing of output
DVD during playback on some players. -
nah its not dvd shrink because i ripped it with dvd shrink, then burned it on a Verbatim DVD-RW and that played fine, then tryed the Ritek and it Freezes 1hour into the movie
just got some new Ritek GO4's today with the White top, tryed them and they worked fine
I've burned over 100 G04's - not a single coaster or disc break up
on play back. -
darz0,
have the same burner,the same firmware and have the same problem....only with Ritek G03. The latest batch of G04's that I have, seem to work fine. I'm just going to stay away from the G03's....not that this helps u, but the Ritek freezing problem is not unique....at least with some people. -
I think it's a disc problem.. I've been through hundreds of G04s and they definitely have a problem with quality control. There are rarely any problems with the burning itself. They all seem to burn fine but the occasional blots in the dye cause pauses in video(from my experience) Check my other topic for details...
https://www.videohelp.com/forum/viewtopic.php?t=209590
Where Are these Ritek CD-Rs Made???
By NBK2 in forum MediaReplies: 19Last Post: 19th Aug 2010, 13:32 -
Ritek: NEVER EVER AGAIN
By mrlar2 in forum MediaReplies: 50Last Post: 15th Aug 2007, 03:13 -
Ritek CD-R White Printable Quality
By mmbetz in forum Newbie / General discussionsReplies: 4Last Post: 18th Jul 2007, 20:32 -
Office Depot brand dvd-r/ Ritek seconds?
By dnix71 in forum MediaReplies: 5Last Post: 31st May 2007, 19:15 -
Ritek Ridata DVD-R 4X G04 where or better?
By Illicious in forum MediaReplies: 8Last Post: 15th May 2007, 10:41
