I am trying to split Scarface onto 2 discs and i get everything to work but when i try to burn, it says it cant realocate my files. I followed the guide on here for IFOEDIT and i followed it correctly. I am kinda confused on the VTS correction feature. When do I do this and HOW?? Do I open ONE ifo file and hit the VTS button? i did that for scarface after i got the burn error and I still got the same error when i try to burn again. I also tried opening it in DVDdhrink and it says i am missing a VOB file that whouldnt be there anyways. It is one from the original rip of the movie so i dont know why it would be needing that since i split it. i hope this isnt confusing...
any suggestions???
I followed this guide when splitting....
https://www.videohelp.com/guides.php?link=248
please help me if you can... thanks
i assume you're trying to back up the first disc of the scarface anniversary edition. i have no idea about splitting it into two disks but here a suggestion if you want to back it up to 1 disc. remove the dts audio since its about 1gig in size, and just keep the dolby digital 5.1 audio. i did this and the size dropped to around 6.6 gigs or so. backed it up with IC8 and its looks damn good, couldnt tell the difference at all. second disc was single layer so it was no problem.
I should have been more specific whenOriginally Posted by jbombs16The run down is this:Originally Posted by I
My own method is slightly different to the above in that I strip out any unnecessary streams using IFOEdit, which transfoms any titleset into VTS_01. Then use Split to 2 DVD-Rs as well as Create VIDEO_TS and VTS_01 IFOs.Originally Posted by Derrow
If this is too hard for you to follow, use Weaselguy's suggestion and shrink it !If in doubt, Google it.
How to copy DVD9 with subtitle & Burn it in DVD-/+R or DVD9
By prithvi in forum Newbie / General discussionsReplies: 15Last Post: 19th May 2010, 11:37 -
DVD9 to DVD9 2 angles layer break problem
By JoeBolden in forum DVD RippingReplies: 4Last Post: 14th Jul 2009, 19:17 -
DVD9 to DVD9 blank
By cadlewv in forum DVD RippingReplies: 7Last Post: 27th Dec 2008, 18:15 -
Splitting a DVD9 into 2 DVD5's with 100% quality?
By alegator in forum DVD RippingReplies: 10Last Post: 22nd May 2008, 16:10 -
having trouble backing up dvd9 to dvd9
By Chunking in forum DVD RippingReplies: 9Last Post: 13th Oct 2007, 20:34
