Hi!
I have just started burning DVDs, re-encoding AVI to MPEG using TMPGEnc, and I have found that whatever I do I always seem to end up with 4:3 aspect ratio images. That is to say, when I try to play back a DVD that has been encoded on TMPGEnc, the screen always defaults to 4:3 on my DVD player and i have to manually set the aspect ratio to the correct setting using my remote. There are black bars across the top as expected, and if I adjust the screen manually I do get a widescreen image, but it does not default to widescreen when I play the MPEG. Instead, I have to cycle through my TVs aspect ratio button until I get widescreen.
Compare this to NERO 6: this re-encodes the same file from AVI to MPEG, but plays it back at its original widescreen settings on my TV without me having to make any adjustments.
How can I adjust TMPGEnc so that it re-encodes a widescreen recording AVI to an MPEG in widescreen and not 4:3? I am using PAL settings. I cannot seem to change the aspect ratio in the video tab, though I can change the source aspect ratio and the video arrange method in the advanced tab (under settings.)
Can someone please help?
Dan
Try clicking Load>Extra>unlock.mcf>open. Then adjust aspect ratio on video tab.
Aspect ratio problems, please help!
By phdutton in forum DVD RippingReplies: 21Last Post: 1st Sep 2011, 07:31 -
By MarioB in forum Newbie / General discussionsReplies: 7Last Post: 2nd Jun 2009, 16:47 -
No aspect ratio 5/4 in Tmpgenc Xpress
By sychern in forum Video ConversionReplies: 1Last Post: 29th Sep 2008, 03:06 -
Aspect Ratio Problems
By Weapon-X in forum EditingReplies: 9Last Post: 9th Mar 2008, 12:38 -
Problems with Aspect Ratio
By qldaussie in forum Video ConversionReplies: 3Last Post: 10th Jan 2008, 11:53
