Less than two months ago I bought a Dell 4600 with a Pentium 2.6 with HT, 512 mb RAMM, and 80gb hd espcially for the purpose of converting vhs tapes and home movies to dvd. I'll probably want to play with editing and authoring as I go along as well. After nearly a month of frustration with the Dell (Roxio) movie package, I sent the package back and began reading up on what to and what not to buy to get the job done.
The overall impression of everything I learned was that everything has quirks. And everyone I talked with who knew anything about video capture and dvd said, "You should have bought a Mac." The only thing I've settled on is a Canopus ADVC-100 to convert analog to DV.
The big question now is whether to get rid of the Dell while I can minimize my loss and get an iMac (or other model), or stick it out with what I have and try to get the best software for the best results. Also, if I am to stick it out, what software package(s) do you suggest?. Any suggestions from the knowing would really be appreciated.
Thanks in advance for your input.
Mike
Results 1 to 11 of 11
I do not own a Mac, but I am successful with making videos on my PC. The great thing these days is while there are several right answers as to which software is best, almost all of them offer trial ware versions so you can play around with the ones you think you may like, and then buy the ones you prefer.
Once you have your AVDC-100 up and running on your system, I suggest you try DVIO for your next capture from analog to DV. It is freeware, very basic and easy to use.
Keep us posted.Hello. -
To add to tommyknocker's suggestions, consider getting TMPGEnc Plus for encoding/editing and TMPGEnc DVD Author for authoring/burning.
Both are solid apps...Always check helpfiles/instructions before leaping... -
Buying a particular type of hardware or software is going to make a negligible difference, if in fact any. You're going to have to actually learn something.
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
You've overcome your biggest hurdle and trust me, the ADVC-100 is a superb investment for what you plan (analogue to DV, right?).
I'm only echoing other posts but....
DVIO to capture from ADVC-100 > Firewire > PC (I use Pinnacle Studio 8.10, I like to edit and add a few light transitions)
TMPGEnc to encode to mpeg2
TMPGEnc Plus to author (I use Ulead Movie Factory 2.0)
My footage of my family on DVD is flawless, all via the ADVC-100.
Will Haytgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
Forgive the expression, but, Don't throw the baby out with the bathwater.
The PC will do the job once you learn the steps it takes to get there.
There are guys/gals on this site working with half the computer you and I use, and doing just fine.
Hang in there."It is not enough to obey Big Brother. You must love him". -
Thanks for all your posts. True, I have to learn something, and I've been doing just that. Since there was not overwhelming advise to go to Mac, I'll stick with what I have and make what I have work. I have been successfully copying DVDs, so now have an idea how to do it. Challenging but pretty cool once it works.
You have a long road ahead.
One of the biggest mistakes I ever made was buying a dell 8200 with all the video editing hardware/software. $2,500.00 down the drain. I then replaced each componant one at a time. Over $1,200.00 more down the drian. All this and not 1 DVD that played consistantly. Did I mention that I have several hundred hours invested. (probably close to 500 hours).
No body is going to be able to help you, not your friends, not people who work on computers that you pay, not certainly not dell, or roxio, you are on your own.
But I now know enough about computers people are starting to bring theres to me for me to fix. Terrific.
Thanks Mike. -
Originally Posted by mike1061Hello.
I a way that was funny. Truth is I now know some about computers, but still don't know how to make a DVD.
Thanks Mike.
Formate/specs for video file which play smoothly Across G4 MAC/ PC /MAC PRO
By krijes in forum EditingReplies: 1Last Post: 2nd Apr 2010, 05:18 -
Entering Video Bitrate Makes Preset Switch To SVCD
By akulier in forum ffmpegX general discussionReplies: 7Last Post: 26th Feb 2008, 05:12 -
By akulier in forum ffmpegX general discussionReplies: 1Last Post: 21st Feb 2008, 04:31 -
DYNEX DX-VS201 s-video switch
By vdotmatrix in forum Media Center PC / MediaCentersReplies: 0Last Post: 24th Dec 2007, 23:24 -
display problem switch from pc to tv, can't switch back
By samiam5156 in forum ComputerReplies: 1Last Post: 11th Oct 2007, 09:23
