Ive tried VirtualVCR and Virtualdub but they both give me errors since my computer has been upgraded. it was fine before but VirtualVCr drives me into a critical blue screen and reboot while Virtualdub seems to tell me that it has encountered errors in one of its routines... Ive got also Pinnacle Studio 8 and its AM capture Tool but it doesnt seem to want to capture in an another directory than my documents (i tried to change and it freezes)... and ive got only like 15Go available in this Drive.
Any other good software or solution, please
thanks in advance
Have you tried intervideo windvd recorder had good results with this program and is very easy to use there is a guide for it on this site
You should be able to change directory. Are you sure that it "freezes" ? When you change dir, PS will check speed of the disk first and this take some time.Originally Posted by DuckyPinnacle Studio 8 and DV home video editing (ver.9 already home)
What's a good way to capture online video with good quality?
By newtie in forum Capturing and VCRReplies: 4Last Post: 19th Feb 2011, 09:41 -
good program??
By rko2164 in forum Software PlayingReplies: 1Last Post: 22nd Dec 2009, 03:14 -
Looking for a good editing program
By JCWBobC in forum EditingReplies: 4Last Post: 8th Sep 2009, 10:15 -
Is there a good Capture program where you can capture in high resolutions?
By Wooooooo in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2008, 11:20 -
Good IM Program?
By Poppa_Meth in forum ComputerReplies: 11Last Post: 10th May 2007, 07:03
