https://www.videohelp.com/guides.php?link=88
i am using that gide
OK, when i used VirtualDub for ANTMSeason1episode1.avi
it worked. But when i tried it with ANTMSeason2episode1.avi i get this error:
I have a screenshot of their properties. I noticed they have a difference in audio codec.
So, would you know how i would make it work?
I do have MicroSoft Audio codec...
Go to the Tools section at left and download them from there.
Hello. -
If you installed both, you have both. They do not overwrite each other. Check again, please.
Hello. -
Ok, i got the Divx 3 file.
It doesn't work. It says something about "not passing Windows logo test"
I installed it anyways. And it still doesn't work
Anyone know a file that works well?
problem with compression using virtual dub
By jpez1 in forum Video ConversionReplies: 4Last Post: 3rd Aug 2010, 13:24 -
Virtual Dub problem
By rocka in forum EditingReplies: 3Last Post: 2nd Jan 2009, 03:46 -
Virtual Dub Mod Saving Problem
By cdgfx84 in forum Video ConversionReplies: 2Last Post: 1st Sep 2008, 13:08 -
Simple Virtual Dub Problem...
By tetzy in forum EditingReplies: 2Last Post: 22nd Feb 2008, 19:49 -
Ripping DVD & Virtual Dub Problem...
By Chana1 in forum DVD RippingReplies: 7Last Post: 8th Jun 2007, 07:45
