  1. I want to know if i can burn one movie on dvd and like an ISO cd burn another movie later on. Can this be done
    OK i'm cheap.
    Dec 2003
    Eugene, Oregon
    Are you asking if you can have two separate burns on the same DVD media? If so, the answer is no; there is no multisession burning to DVD media.
  3. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    ill 2nd that
    just get dvdrw if you want to reuse your media
  4. Just what i thought. I was asking because the AVI movies i have are less than a Gig and i think its just a waste of a disc.
    Sorry i have no dvdrw at the moment but will get some.
    Thanks for the replys
