I have a good quality avi at 1236 kps. Here is the info from avicodec "Video : 177 MB, 1236 Kbps, 23.976 fps, res. 512*384 (4:3), DIV3 = DivX v3MPEG-4 (Low-Motion), Supported" ... if it is at 1236 what would be the best setting for an dvd converion? What would be the best bitrate to get 100% quality yet keep the size as small as possible without quality loss..
Thanks for the help
8)
Use the bitrate calculator here: https://www.videohelp.com/calc.htm
That calculator will tell you the maximum possible bitrate for your movie, so you can use that when you do your encoding. -
i was wondering the same thing - i was testing an mpeg i made with 6000kbits and 4135kbits and both look the same on my computer, but i'm sure it will prob look diff on a tv - Pinnacle's default is 6000 when you capture in mpeg format - the default on that calculator is 6548 - not sure here.....
Well the good thing about that bitrate calculator is that there is no "default" per se. The calculator gives you the bitrate to use based on how long your movie is, what the bitrate of your audio is, and what kind of media you want to fit it on.
So let's say you have a Divx movie that is 2 hours, 30 minutes, and 16 seconds. Let's say you extracted the audio and converted it to a 224 kbits/sec AC3 file. Let's also say you want to fit everything onto 1 DVDR (DVD-5). You would input all that info into the calculator, and it would compute the max bitrate you shoudl use so that everything fits onto 1 DVDR disc. Then you can convert your movie with CBR encoding in TMPGEnc with the calculated bitrate.
If you're still confused, read the DVDRhelp guide about converting a Divx movie with AC3. This guide shows you how to use the bitrate calculator in the overall process: https://www.videohelp.com/forum/userguides/186739.php -
Thanks GUYS! DVDRHELP/VCDHELP is the greatest, This is the place where I learned how to make perfect SVCD, now I got a DVD player.. this is the first place I went.. thanks again guys
(BTW the way got the TDK 8x dvd-r and dvd-r+ multi format for 182 on pricewatch,,... it rocks)
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 16:01 -
Bitrate question compiling a DVD
By dvdnewb2 in forum Video ConversionReplies: 6Last Post: 18th Aug 2008, 09:31 -
Subtitle question for PS3 owners and experts....
By siratfus in forum SubtitleReplies: 1Last Post: 26th Jul 2008, 00:27 -
Bitrate question for Avi to Wmv conversion w/ Windows Media Encoder
By Gonz0ne in forum Video ConversionReplies: 5Last Post: 6th Jan 2008, 09:19 -
This Is A Loaded Question For You Video/Audio Experts Out There...
By pmolson in forum Newbie / General discussionsReplies: 2Last Post: 20th May 2007, 14:32
