What makes these so much different than other avi? it said something about ac3 audio encoding. Is this something that can be easily turned into a VCD or DVD? I tried using Divx Doctor II, but it wouldn't really let me turn it to a .mov. Any suggestions?
Assemble your crew, I'll meet you outside.
You can turn these into a vcd or svcd with ffmpegx if you (on the options tab) decode with mplayer and not quicktime (this takes a long time, approx 12hrs/movie on a 667mhz G4 ). Just choose SVCD preset (or VCD or DVD etc)and then on the options tab select the mplayer checkbox (also uncheck letterbox if the source is 4:3).
About ac3: Quicktime wont normally playback ac3 sound (which is why we used mplayer and not quicktime in the ffmpegx instructions above). There is a free ac3 codec available out there so you will get sound when you playback in QT. This may even allow you to use QT decoding in ffmpeg but I havent tried that.
Edit: The ac3 codec is at http://www.insaneness.com/ac3.html
Cheers,
VirtualDub/Xvid question: YV12 vs. XVID FourCC in the xvidvfw.dll driver???
By KneeRow in forum Video ConversionReplies: 14Last Post: 1st Aug 2010, 13:35 -
Does xvid cli (command line version of xvid) actually exist ?
By vhelp in forum ProgrammingReplies: 10Last Post: 29th Oct 2009, 14:18 -
help combining 2 xvid avis and 2 subtitles (srt) to 1 xvid avi
By hibbs in forum SubtitleReplies: 4Last Post: 14th Jun 2009, 19:05 -
How to encode an xvid file to another xvid and prevent video blocking?
By BlooderButcher in forum Video ConversionReplies: 5Last Post: 21st Nov 2008, 16:03 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 11:47
