Hello, all:
Recently installed/ran SVCD2DVD. Output looks very nice, but noticed that it's shifted all the way over to the left side of the screen.
The aspect is fine, though. Tried using DVDPatcher with same results, regardless of aspect ratio chosen.
Is there any way to have the output centered on the screen?
Thanks, but I actually meant that it appears shifted on the PC screen when I play it - regardless of what aspect ratio I choose, regardless of what mpg player I use, and regardless of patcher - SVCD2DVD or DVDPatcher.
I haven't actually tried to burn it to a DVD. It seemed pretty obvious that how it shifted on the monitor was how it would burn/show up on the DVD when played.
I would think that to put in a little routine that checks and centers the output - or allows you to make adjustments (similar to TMPGEnc) would be relatively easy to incorporate. -
So is this the authored DVD or just the mpgs which have been patched?
AVI problem: AVIStreamRead return results shifted
By videu in forum Newbie / General discussionsReplies: 5Last Post: 7th Apr 2010, 20:41 -
Black space on bottom and left/video shifted?
By divergex in forum Newbie / General discussionsReplies: 4Last Post: 30th Jun 2009, 21:32 -
Possible to output hdmi and optical output on the ps3??
By mrswla in forum DVD & Blu-ray PlayersReplies: 10Last Post: 3rd Feb 2009, 16:17 -
DVD output video is cut off on left and right
By Grunberg in forum Authoring (DVD)Replies: 6Last Post: 10th Nov 2007, 19:18 -
Converting a Mono Left Channel to Double Mono Left/ Right Channel on a DVD
By socool135 in forum AudioReplies: 5Last Post: 16th Sep 2007, 01:45
