  1. I did a search but couldn't find answer.. I have two Pioneer burners--A05 and a 106d.
    I've tried Nero, IC and DVDDecrypter to write to 2 burners at the same time without success.. I keep getting various errors. For example, when i'm writing with DVDDecrypter to one burner and try to begin writing to the other burner with either IC or Nero, Decrypter instantly gives me an error.. I have the 2 burners on separate channels.
    Can someone advise, please? Thanks.
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    well it works using only one burning app - like prassi or nero ...
    prassi allows you to burn different things at once and nero the same thing at once ...
  3. Well, I've tried burning a project to multiple burners with Nero 5.5.10... I'll have to figure out what I'm doing wrong..
    But Prassi will allow burning different projects to mulitple burners at the same time?? I'll have to pick it up. Thanks.
    Feb 2004
    WI.
    Do both burners have buffer underrun protection? If not that could be your problem.
  5. Prassi= record now max
    At any rate I don't use Prassi with Nero, but you can use RNM with Nero.
    In the future give all your system specs it makes it easier for us.
  6. You're right.. sorry, I s/h provided my system specs: XP Pro, P4 3.0G, 1G DDR400 RAM, Lite-on DVD-ROM, Pioneer A05 and 106.
    I really don't quite understand 'buffer under run'.. But I do see that it does act 'irratic' when i attempt 2 burns simultaneously.. How can i tell if my burners offer 'buffer under run'? Thanks.
