Hi. Is it possible to rip two movies at the same time. I figure it will probally take lots of CPU usage, BUT is it possible? Thanks for any replies.![]()
If you have two DVDROMS, I don't see why not.
CPU useage is less likley to be a problem than disc access times (both DVDRom's and HD). -
As I said, I would expect the bottleneck to be the disk drives. I would not expect you to be able to rip two DVD's in the same time as ripping one DVD because of this. Exactly how much difference you would see depends very much on the system configuration.
As to running DVDshrink twice, thast a very different question. Dvdshrink is much more than a ripper. When it is transcoding then CPU power does become an issue. As to wether you can run two instances at the same time I don't know. Try it. Most apps will allow this but some don't. -
I agree with bugsters' post, but would also like to add that ripping speed might be enhanced when ripping if the destination of the rip is on 2 different hard drives.
Use two PCs.
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
Best way to rip blocky or Compressed Dvd movies?
By Bharathnat in forum DVD RippingReplies: 7Last Post: 4th Nov 2011, 10:55 -
Can't Rip Harry Potter Movies
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 16th Dec 2010, 06:06 -
Want to Rip DVD movies !
By augustya in forum DVD RippingReplies: 23Last Post: 24th Sep 2010, 20:57 -
Help reset my expectations - how big the rip will be, time it takes to..
By AndyD in forum Blu-ray RippingReplies: 3Last Post: 26th Nov 2009, 13:10 -
$35.00 for the movies (or how to rip off the public)
By FulciLives in forum Latest Video NewsReplies: 18Last Post: 26th Oct 2008, 00:20
