downloaded the most recent version of tmpgenc but could not install it since i needed to uninstall the previous one. that seems to have gone wrong although i used uninstall directly, then again the systems/software route under XP, then deleted all registry entries. the newer version starts the installation process then stops half way through with an error message that the old version can not be uninstalled. Can you help?
Alternatively, where do i find older tmpgenc versions. may be it is easier for me to re-install the old version and live with that.
thanks
jens
