  1. Hello major,
    please help: recorded a film from German TV ARD from sat DVB with a dreambox (ts file), demuxed with ProjectX to *.mpv and *.mp2.
    data of video *.mpv displayed in ProjectX:
    -> video basics: 720*576 @ 25fps @ 0.7031 (16:9) @ 1490800bps, vbvBuffer 91
    result after trying to create dvd image:
    INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
    INFO: [mplex] File /Filme/demux/Frau 16_9.mpv looks like an MPEG Video stream.
    INFO: [mplex] File /Filme/demux/Frau16_9.mp2 looks like an MPEG Audio stream.
    INFO: [mplex] Video stream 0: profile 8 selected - ignoring non-standard options!
    INFO: [mplex] Found 1 audio streams and 1 video streams
    INFO: [mplex] Selecting dvdauthor DVD output profile
    INFO: [mplex] Multiplexing video program stream!
    INFO: [mplex] Scanning for header info: Video stream e0 (/Filme/demux/Frau 16_9.mpv)
    INFO: [mplex] VIDEO STREAM: e0
    INFO: [mplex] Frame width : 720
    INFO: [mplex] Frame height : 576
    INFO: [mplex] Aspect ratio : 16:9 display
    INFO: [mplex] Picture rate : 25.000 frames/sec
    INFO: [mplex] Bit rate : 5414400 bits/sec
    INFO: [mplex] Vbv buffer size : 186368 bytes
    INFO: [mplex] CSPF : 0
    INFO: [mplex] Scanning for header info: Audio stream c0 (/Filme/demux/Frau16_9.mp2)
    INFO: [mplex] MPEG AUDIO STREAM: c0
    INFO: [mplex] Audio version : 1.0
    INFO: [mplex] BUFFERING min 15 Buf max 587
    INFO: [mplex] MUX STATUS: no under-runs detected.
    ERR: bad version of getopt; please precede all sources with '-f'
    *.mpg created ok, correct view in Quicktime as 16:9 (in Finder also in QT size is 720x404 - ??) - but no dvd image or folder structure.
    Sizzle creates working DVD - but I want to use ffmpegX, of course
    dvdauthor problem? - thanks, Martin59
    (registered ffmpegX Feb 19, 2004)
  2. Originally Posted by Martin59
    *.mpg created ok - but no dvd image or folder structure.
    Try to run the "Author" tool on the mpg file.
  3. Major,
    thanks for fast answering.
    In the meantime I succeeded.
    1. in ProjectX I initially let the option "DAR" 0.7031 (16:9) unchecked (because I did not need it in my ol' windows days with the ProjectX/IfoEdit combo) - and got a vertically stretched picture, no 16:9 pan&scan
    (The true problem was: the first 2 GOPs I choosed to demux were still 4:3, so the whole film was interpreted as 4:3 although it changed just on the 3rd GOP to 16:9 - so no need to check that box if I started with the first 16:9 GOP)
    2. after checking the option, I did a mistake in renaming the files (let a space in file name). see this line:
    corrected that: authoring with ffmpegX runs smoothly, creates perfect DVD folders&image
    3. so no need to use the "author" recommendation (btw which only works on valid file names, too).
    Lots of thanks - works excellent now.
    Martin59
    BTW which file names are valid? no spaces- ok; ol' DOS rules 8.3? UNIX newbie ...
  4. Originally Posted by Martin59
    Best is to use letters, numbers, and underscores only.
