After reading around on here i thought id go for dvd lab to use to author and what an excellent prog it is! Only problem being i have spent ages sorting out a syncing problem finally got it working and now when i put the film on a dvd-r it loses sync!
I would say its at the last 20-30 minutes and is very minimal but its something that annoys me !
Is there anything i can do to stop this i did go out about getting my file a strange way but didnt think that would make a differnece!!?!
Thanks for any help sorry if this is posted in the wrong place
Tell us more about the sources:
Where did the video come from? audio?
Was it originally PAL or NTSC?
Were they elementary streams or did they exist as a VOB?-----------------------------------------------------
There is a reason why God gave us one mouth and two ears!!! -
Ok heres the way i got it!
Downloaded and xvid at 23.976 opened in vdub extracted audio then saved as avi changing framrate to 25fps used goldwave to match audio with video length, used vdub to use THAT audio and the avi which is now 25fps....Result a perfectly synched avi.
Use mainconcept to conver to mpeg2 that resulted in a perfect looking mpeg2 no synching problems whatsoever then made a little menu in dvdlab and saved all the files.
Used nero to burn to dvd
put in dvd player excellent quality and for about the last 20 mins the mouths are faster than the words! ! ! -
It seems a consistent theme, downloaded video seem to contribute to the majority of issues that people have with authoring their DVDs.
You don't know who/how/what the person encoding did to the video.
Expect unpredictable results. -
andkiich,Originally Posted by andkiich
I agree 100% . Seems like the root causes of "poor sync" or "jerky" or "no audio" etc. etc. etc. have their start with downloaded material from the 'net. Now mix in edits by combining MPEG2 with DIVX with XVID with Huffy with 2:3 and 3:2 pulldowns and ..... . Then the user has the nerve to say the tool is at fault. IF people work with compliant elementary streams so many of these problems would go away.
ryfool - This is not a shot at you personnally. So many posts here complain about the software tool's quality but never the source they're trying to use.
As andkiich said, if you don't know the sources, expect problems.-----------------------------------------------------
DVDLab never changes or messes up the audio and video streams given to it. That's one of the best things about it IMO.
I've had lots of trouble when converting XVid and MPEG4 video to DVD/SVCD format. Most of the time it works, but 10% of the files have something about them that justs crashes/aborts the conversion.
Greg -
Can mainconcept output m2V and mpa files ?Originally Posted by ryfool
If so then please try the simple Author function in IfoEdit.
Thats a different muxing engine and the comparrison would be of interest - if different.
Plus - if it does work then use the VOB directly in DVDLab to see if its better.
cheers
maa
More dvd lab questions
By sterankin in forum Authoring (DVD)Replies: 12Last Post: 16th Aug 2010, 17:13 -
Help with DVD-lab PRO.
By angles in forum Authoring (DVD)Replies: 2Last Post: 3rd Jan 2010, 18:19 -
DVD Lab question
By sumeshkri in forum Authoring (DVD)Replies: 5Last Post: 13th Nov 2008, 22:32 -
DVD Lab 2 error
By XL3/\/7 in forum Authoring (DVD)Replies: 4Last Post: 3rd Jun 2007, 07:54 -
DVD Lab Help!
By ardiani in forum Newbie / General discussionsReplies: 14Last Post: 25th May 2007, 08:52
