What is the easiest way to extract audio tracks from a DVD into wav or mp3 ?
There may be an easier way but this is how I do it -
Rip the movie only (or whatever part of the dvd you want) using DVD Decrypter in IFO mode. Under the Input tab make sure the part that you want is selected, you can even do individual chapters if you wish. Click on stream processing and deselect all the parts you do not need.
For the conversion to mp3/wav I use Headac3he. To enable it to output in mp3 format you must have the lame_enc.dll in the Headac3he directory, I already had Cdex installed so I simply copied and pasted the lame_enc.dll file. Have a look at this screenshot, as you can see it's all very simple. To open the mp3 options simply click options twice. The settings I have used give a constant bitrate of 128kbps. Works for me.
Rip with DVDDecrypter
Demux with ReJig
Decode to wav with headac3he (if it's AC3)
/Mats -
HHmm..Mats method just adds an extra step though, why the need for Rejig ?.. DVDdecrypter can give you the audio stream on its own.
There are a couple of DVD to mp3 audio ripping programs but I found the quaility and/or volume was lacking in those. -
Yes, you're quite right. Didn't think of that.DVDdecrypter can give you the audio stream on its own.
/Mats -
yEP...DVD audio ripper is what i used, but I wasnt that impressed.
I prefer the DVDDec/Headac3he method, although if the DVD has a PCM soundtrack (a lot of music ones do) then you dont need headac3he although you may need to convert your 48khz wav/mp3 to 44.1, my lil mp3 player can play 48khz ok though.
Easy way to extract (demux) audio tracks from Blu-ray folder?
By ricsee in forum Newbie / General discussionsReplies: 2Last Post: 11th May 2011, 12:12 -
HOW do I extract 1 audio track from a .ts / .m2ts with 4 audio tracks?!
By elgy in forum DVB / IPTVReplies: 25Last Post: 24th Jan 2011, 00:28 -
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 02:56 -
DVD to MPEG2, extract mult audio tracks, subtitles for replay in WD TV Live
By Jacoman in forum DVD RippingReplies: 5Last Post: 16th Mar 2010, 10:40 -
Extract / isolate 5.1 audio tracks from DVD
By soundchaser in forum MacReplies: 0Last Post: 16th Mar 2009, 13:21
