I tried to encode a MPEG2 file made from TMPEG and AC3 file from DVD2AVI to create a new VOB file but when I hit create VOB it said process completed after less than a second and it didn't even create anything. Does anyone have any ideas?
My experience is from SpruceUp, but some of this may help:
The video should be full resolution, either 352x480/576, or 720x480/576. Also, make sure the file name extension is m2v, and make sure you rename your AC3 demultiplexed file to the exact same name as your TMPGEnc video file (e.g., movie.m2v; movie.ac3). -
Yeah, I tried Spruce Up originally but it takes so long to import, build your menu, and then create the image to burn. So I was trying quickbuilder to see if it would be any quicker, I know its menus suck but I figured if I had one menu built already that I could use over and over, that it might work ok. I'm trying to put two dvd movies on one dvdr disk and am looking for a quicker way to get to the final product than sitting through 2-3 hours of build time before I can burn my disk.
