I burned a DVD on a Mac and brought it home to work on it on my PC. The problem: XP doesn't even recognize the disk. Nero sees it but only as a Mac formatted disk, no files. I really need those files. Anybody know how I can get them off the disk?
Results 1 to 10 of 10
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
well the only way i can think of is to take it back to the mac, and find a way to reburn the dvd that windows will recognize. im not familiar with macs, so i dont know.
That's what I don't know. I used Disk Copy in the Utilities folder. Its the only burning program (that I know of) on those computers. This is so much easier on a PC.
I would think that Disc Copy would have worked... like you need to get toast if you want to burn cross platform with any reliability.
I didn't even think Macs still burned HFS. You need to burn it as ISO or UDF so the PC can read it. Or you need to get an HFS reader for your PC so you can view Mac formatted stuff.
The problem is that these computers are at school. I can't install anything on them without a password. That HFS reader sounds like my only choice. You know of any good ones?
EDIT: Can disc copy burn in udf? It didn't mention anywhere what the file format was.His name was MackemX
I know this is anchient....... but just fyi
1. disk copy doesnt do UDF as default [as its used by the finder for burning and finder burns are data by default]
2. you can do UDF but it requires one small step using dvdimager. Just make a .img of your VIDEO_TS folder. This makes a UDF format image which you can burn with disk copy as UDF
hope this makes since! -
Holy crap, I'd forgotten about this. Thanks for the info. I bought an external hard drive so that solved the problem. Also an instructor has toast installed on his G4 so I just used that.
cool...... just wanted to let ya know it is doable.... for future reference
something like Reclock on OSX??
By svdf in forum MacReplies: 4Last Post: 16th Dec 2011, 00:26 -
What is the best way to remux a mkv to dvd on mac osx?
By soundguy15 in forum Video ConversionReplies: 3Last Post: 16th Nov 2011, 16:39 -
Guide How to make a dvd with selectable subtitles on Mac OSX with ffmpegX
By ulmis in forum ffmpegX general discussionReplies: 29Last Post: 24th Nov 2010, 11:54 -
How do I rip subtitles only from a DVD in OSX?
By jakeknotts in forum MacReplies: 2Last Post: 1st Mar 2010, 20:22 -
MP4BOX 0.4.5 for OSX
By cvkB in forum MacReplies: 3Last Post: 17th Oct 2009, 18:51
