  1. I used DVD Shrink to extract several segments of various DVDs for a compilation that I'm making. The resulting VOB clips play just fine in with PowerDVD. I want to join all these clips together in MPEG2VCR so I can have one big file to burn (the reason being that when I just burn a compilation, there is inevitably a visible stutter between each file during playback). Whenever I join the clips together in MPEG2VCR, though,, the audio sync gets messed up. It seems to be about 4 seconds behind the video. Any ideas on what could be causing this? Why would it play fine in one app but not in MPEG2VCR? I'm a relative novice at this, so this might be a stupid question: do i need to do something to the files before attempting to join them? Any help would be much appreciated.
  2. Always check helpfiles/instructions before leaping...
  3. Originally Posted by rcb
    https://www.videohelp.com/guides.php?link=538
    Unfortunately that doesn't help me, because as I noted above, when I go through that process using DVD Shrink, there is always a stutter during playback between the different files I burned. Any other ideas?
