I have a Dell inspiron 5100 laptop and a HL-DT-ST RW/DVD GCC-4240N Slim DVD player inside it. Whenever I try to play a burned dvd on my laptop it freezes after a few minutes of playing. This doesn't happen on the DVD player in my brother's tower or in our stand-alone player. I tried asking Dell and of course they have no idea. Please help me.
You are in breach of the forum rules and are being issued with a formal warning. one topic is enough / Moderator BJ_M
Closed Thread
well that still doent mean that yo ahve to post it many times. just post it in the most correct forum ad it will get answered in a day or two.
anyway, does this problem happen if you play it on a standalone player? if not, the problem is with your laptop. try another software, like windows media player, or update the software you have.
It does work on my stand-alone as I said in my first post, and I updated my software and I tried, WinDVD, PowerDVD and Windows Media Player.
what brand of disks are the movies burned on?
are the disks r-, r+, rw?
are those type of disks compatible with your dvd-rom drive?
have you checked dell website for new firmware upgrades for your dvd-rom drive?
have you checked the dvd-rom manufacturing website to see if they have a knowledge base you can check?
can your dvd-rom drive read normal commercially made dvd's?
do you have the most updated drivers for your dvd-rom drive/ide controller?
is your dvd rom drive set to pio/dma?
how does it not play? are you able to rip the dvd to your hd and play the movie from your hd? are there scratches on the disk?
a little bit more info would be helpful.
what brand of disks are the movies burned on? Memorex 4x DVD-R
are the disks r-, r+, rw? DVD-R
are those type of disks compatible with your dvd-rom drive? Yes
have you checked dell website for new firmware upgrades for your dvd-rom drive? Yes and there were none
have you checked the dvd-rom manufacturing website to see if they have a knowledge base you can check? The company that makes the CD-ROM Drive I use no longer exists
can your dvd-rom drive read normal commercially made dvd's? Yes
do you have the most updated drivers for your dvd-rom drive/ide controller? Yes
is your dvd rom drive set to pio/dma? I don't know.
how does it not play? After five to ten minutes of play time it freezes and locks up the program
are you able to rip the dvd to your hd and play the movie from your hd? Haven't tried but I would rather not, cause I have a lot of DVDs and I like my hard drive free
are there scratches on the disk? No.
What's the CPU speed of your laptop? 2.39 GHz
Does it happen with both + and - disks? I don't know. Haven't tried + but I really don't want to as the burner I use is in california and I am in Hawaii.
Which program are you using to play the DVDs? Pleas try to read the posts you respond to. As I said earlier, WinDVD, PowerDVD and Windows Media Player.
No sound when playing playing burned DVD on stand alone player
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2010, 13:11 -
Compatibility of burned DVDs
By cool612 in forum Newbie / General discussionsReplies: 3Last Post: 7th Jun 2010, 21:16 -
having complications with certain dvds not playing on my laptop
By robdutka in forum DVD & Blu-ray PlayersReplies: 1Last Post: 10th May 2010, 04:39 -
DVDs work in desktop PC but not in laptop - previously worked in laptop
By Brent Jewell in forum Newbie / General discussionsReplies: 3Last Post: 6th Nov 2008, 19:40 -
Trouble playing burned DVDs on my stand alone
By collin_stevens in forum MacReplies: 2Last Post: 12th Oct 2007, 16:51
